Charmed PostgreSQL
- Canonical
latest/stable | 591 | 10 Apr 2025 | |
latest/stable | 239 | 09 Feb 2022 | |
latest/stable | 226 | 01 Apr 2021 | |
14/stable | 553 | 04 Feb 2025 | |
14/stable | 552 | 04 Feb 2025 | |
14/candidate | 593 | 16 Apr 2025 | |
14/candidate | 592 | 16 Apr 2025 | |
14/beta | 605 | 27 Apr 2025 | |
14/beta | 606 | 27 Apr 2025 | |
14/edge | 741 | 06 May 2025 | |
14/edge | 740 | 06 May 2025 | |
16/candidate | 610 | 25 Apr 2025 | |
16/candidate | 609 | 25 Apr 2025 | |
16/beta | 610 | 24 Apr 2025 | |
16/beta | 609 | 24 Apr 2025 | |
16/edge | 758 | 07 May 2025 | |
16/edge | 757 | 07 May 2025 |
juju deploy postgresql --channel 14/stable
22.04
20.04
18.04
16.04
14.04
System requirements
The following are the minimum software and hardware requirements to run Charmed PostgreSQL on VM.
Software
- Ubuntu 22.04 (Jammy) or later.
Juju
The charm supports several Juju releases from 2.9 LTS onwards. The table below shows which minor versions of each major Juju release are supported by the stable Charmhub releases of PostgreSQL.
Juju major release | Supported minor versions | Compatible charm revisions | Comment |
3.6.1+ |
552+ | 3.6.0 is not recommended, while 3.6.1+ works excellent. Recommended for production! |
3.5.1+ |
363+ | Known Juju issue in 3.5.0 |
3.4.3+ |
363+ | Know Juju issues with previous minor versions | |
3.3.0+ |
from 363 to 430 | No known issues | |
3.2.0+ |
3.1.7+ |
from 336 to 430 | Juju secrets were stabilized in 3.1.7 |
2.9.49+ |
288+ | ||
2.9.32+ |
from 288 to 430 | No tests for older Juju versions. |
Hardware
Make sure your machine meets the following requirements:
- 8GB of RAM.
- 2 CPU threads.
The charm is based on the charmed-postgresql snap. It currently supports:
amd64
arm64
(from revision 396+)
Contact us if you are interested in a new architecture!
Networking
- Access to the internet is required for downloading required snaps and charms
- Only IPv4 is supported at the moment
- See more information about this limitation in this Jira issue
- Contact us if you are interested in IPv6!
