Vault
| 2.0/beta | 565 | 23 Jun 2026 | |
| 2.0/edge | 570 | Today | |
| 2.0/edge | 569 | Today | |
| 2.0/edge | 565 | 18 Jun 2026 | |
| 1.19/stable | 528 | 21 Apr 2026 | |
| 1.19/candidate | 528 | 03 Apr 2026 | |
| 1.19/beta | 528 | 03 Apr 2026 | |
| 1.19/edge | 544 | 04 May 2026 | |
| 1.19/edge | 543 | 04 May 2026 | |
| 1.18/stable | 534 | 01 Jul 2026 | |
| 1.18/candidate | 534 | 01 Jul 2026 | |
| 1.18/beta | 534 | 01 Jul 2026 | |
| 1.18/edge | 534 | 09 Apr 2026 | |
juju deploy vault-k8s --channel 1.16/stable
Connecting to Vault
