postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 559 15 Apr 2025
14/candidate 558 15 Apr 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 603 07 May 2025
14/edge 602 07 May 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 601 07 May 2025
Ubuntu 24.04
16/edge 600 07 May 2025
Ubuntu 24.04
juju deploy postgresql-k8s --channel 14/stable
System Requirements
The following are the minimum software and hardware requirements to run Charmed PostgreSQL on K8s.
Software
  • Ubuntu 22.04 LTS (Jammy) or later.
Juju
The charm supports several Juju releases from 2.9 LTS onwards. The table below shows which minor versions of each major Juju release are supported by Charmed PostgreSQL.
Juju major release Supported minor versions Compatible charm revisions Comment
3.6 LTS 3.6.1+ 444/445+ Recommended for production.
3.5 3.5.1+ 280+ Known Juju issue in 3.5.0
3.4 3.4.3+ 280+ Know Juju issues with previous minor versions
3.3 3.3.0+ from 177 to 193 No known issues
3.2 3.2.0+ from 177 to 193 No known issues
3.1 3.1.7+ from 177 to 193 Juju secrets were stabilized in 3.1.7
2.9 LTS 2.9.49+ 73+
2.9.32+ 73 to 193 No tests for older Juju versions.
Kubernetes
  • Kubernetes 1.27+
  • Canonical MicroK8s 1.27+ (snap channel 1.27-strict/stable and newer)
Hardware
  • 8GB of RAM.
  • 2 CPU threads.
  • At least 20GB of available storage.
  • Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on the charmed-postgresql snap. It currently supports:
  • amd64
  • arm64 (from revision 211+)
The charm is based on the ROCK OCI named charmed-postgresql.
Contact us if you are interested in new architectures!
Networking
At the moment IPv4 is supported only (see more info).
Contact us if you are interested in IPv6!
